Time Before: 0.00141 seconds
Time After: 0.00197 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00204 seconds
Time After: 0.00252 seconds
Time Before: 0.00271 seconds
Time After: 0.00284 seconds
Time Before: 0.00349 seconds
Time After: 0.00588 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00288 seconds
Time After: 0.01018 seconds
Time Taken: 0.00730 seconds
Time Before: 0.01190 seconds
Time After: 0.01238 seconds
Time Before: 0.01468 seconds
Time After: 0.01591 seconds
Time Before: 0.01135 seconds
Time After: 0.01610 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02287 seconds
Time After: 0.02302 seconds
Time Before: 0.02514 seconds
Time After: 0.02645 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.028209209442139
Time Before: 0.02932 seconds
Time After: 0.02948 seconds
Time Before: 0.03149 seconds
Time After: 0.03294 seconds
SET lastactivity = 1782993972, location = '/forums/private.php?do=newpm&explain=1&u=125269', badlocation = 1
Time Before: 0.04778 seconds
Time After: 0.04809 seconds
Page generated in 0.046581029891968 seconds with 9 queries, spending 0.008080005645752 doing MySQL queries and 0.038501024246216 doing PHP things.
