Time Before: 0.00140 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00235 seconds
Time Before: 0.00262 seconds
Time After: 0.00276 seconds
Time Before: 0.00359 seconds
Time After: 0.00605 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00284 seconds
Time After: 0.00946 seconds
Time Taken: 0.00662 seconds
Time Before: 0.01142 seconds
Time After: 0.01186 seconds
Time Before: 0.01577 seconds
Time After: 0.01865 seconds
Time Taken: 0.00288 seconds
Time Before: 0.01067 seconds
Time After: 0.01891 seconds
Time Taken: 0.00824 seconds
Time Before: 0.02584 seconds
Time After: 0.02606 seconds
Time Before: 0.02894 seconds
Time After: 0.03017 seconds
Time Before: 0.03357 seconds
Time After: 0.03379 seconds
Time Before: 0.03591 seconds
Time After: 0.03734 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=125271' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05232 seconds
Time After: 0.05263 seconds
