Time Before: 0.02169 seconds
Time After: 0.02701 seconds
Time Taken: 0.00532 seconds
Time Before: 0.02712 seconds
Time After: 0.02753 seconds
Time Before: 0.02776 seconds
Time After: 0.02792 seconds
Time Before: 0.02868 seconds
Time After: 0.03143 seconds
Time Taken: 0.00274 seconds
Time Before: 0.02799 seconds
Time After: 0.03535 seconds
Time Taken: 0.00736 seconds
Time Before: 0.04320 seconds
Time After: 0.04360 seconds
Time Before: 0.04597 seconds
Time After: 0.04714 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04251 seconds
Time After: 0.04733 seconds
Time Taken: 0.00483 seconds
Time Before: 0.08609 seconds
Time After: 0.08807 seconds
Time Taken: 0.00198 seconds
Time Before: 0.29257 seconds
Time After: 0.29397 seconds
Time Taken: 0.00139 seconds
Time Before: 0.30055 seconds
Time After: 0.30075 seconds
Time Before: 0.30329 seconds
Time After: 0.30499 seconds
Time Taken: 0.00169 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=125297', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.32436 seconds
Time After: 0.32460 seconds
