Time Before: 0.01161 seconds
Time After: 0.01729 seconds
Time Taken: 0.00569 seconds
Time Before: 0.01738 seconds
Time After: 0.01786 seconds
Time Before: 0.01807 seconds
Time After: 0.01818 seconds
Time Before: 0.01895 seconds
Time After: 0.02109 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01825 seconds
Time After: 0.02509 seconds
Time Taken: 0.00684 seconds
Time Before: 0.03078 seconds
Time After: 0.03116 seconds
Time Before: 0.03380 seconds
Time After: 0.03500 seconds
Time Before: 0.03012 seconds
Time After: 0.03518 seconds
Time Taken: 0.00506 seconds
Time Before: 0.05545 seconds
Time After: 0.05560 seconds
Time Before: 0.06437 seconds
Time After: 0.06632 seconds
Time Taken: 0.00195 seconds
End call of global.php: 0.068574905395508
Time Before: 0.07565 seconds
Time After: 0.07586 seconds
Time Before: 0.07944 seconds
Time After: 0.08098 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=125304', badlocation = 1
Time Before: 0.09839 seconds
Time After: 0.09871 seconds
Page generated in 0.097347974777222 seconds with 9 queries, spending 0.0084874629974365 doing MySQL queries and 0.088860511779785 doing PHP things.
