Time Before: 0.01281 seconds
Time After: 0.02227 seconds
Time Taken: 0.00947 seconds
Time Before: 0.02236 seconds
Time After: 0.02278 seconds
Time Before: 0.02302 seconds
Time After: 0.02323 seconds
Time Before: 0.02416 seconds
Time After: 0.02682 seconds
Time Taken: 0.00266 seconds
Time Before: 0.02333 seconds
Time After: 0.03179 seconds
Time Taken: 0.00846 seconds
Time Before: 0.04159 seconds
Time After: 0.04204 seconds
Time Before: 0.04508 seconds
Time After: 0.04634 seconds
Time Before: 0.04082 seconds
Time After: 0.04656 seconds
Time Taken: 0.00574 seconds
Time Before: 0.07896 seconds
Time After: 0.07912 seconds
Time Before: 0.09637 seconds
Time After: 0.09764 seconds
Time Before: 0.11249 seconds
Time After: 0.11269 seconds
Time Before: 0.11555 seconds
Time After: 0.11703 seconds
UPDATE session SET lastactivity = 1783155929, location = '/forums/private.php?do=newpm&explain=1&u=125320' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.13735 seconds
Time After: 0.13770 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
