Time Before: 0.00867 seconds
Time After: 0.01118 seconds
Time Taken: 0.00251 seconds
Time Before: 0.01129 seconds
Time After: 0.01174 seconds
Time Before: 0.01196 seconds
Time After: 0.01210 seconds
Time Before: 0.01278 seconds
Time After: 0.01623 seconds
Time Taken: 0.00345 seconds
Time Before: 0.01217 seconds
Time After: 0.02044 seconds
Time Taken: 0.00827 seconds
Time Before: 0.02498 seconds
Time After: 0.02543 seconds
Time Before: 0.02737 seconds
Time After: 0.02875 seconds
Time Taken: 0.00139 seconds
Time Before: 0.02435 seconds
Time After: 0.02894 seconds
Time Taken: 0.00460 seconds
Time Before: 0.04314 seconds
Time After: 0.04331 seconds
Time Before: 0.05241 seconds
Time After: 0.05367 seconds
End call of global.php: 0.056035995483398
Time Before: 0.06179 seconds
Time After: 0.06199 seconds
Time Before: 0.06453 seconds
Time After: 0.06598 seconds
SET lastactivity = 1788872175, location = '/forums/private.php?do=newpm&explain=1&u=125335', badlocation = 1
Time Before: 0.08278 seconds
Time After: 0.08323 seconds
Page generated in 0.0816810131073 seconds with 9 queries, spending 0.009413480758667 doing MySQL queries and 0.072267532348633 doing PHP things.
