Time Before: 0.01054 seconds
Time After: 0.01299 seconds
Time Taken: 0.00245 seconds
Time Before: 0.01308 seconds
Time After: 0.01356 seconds
Time Before: 0.01388 seconds
Time After: 0.01400 seconds
Time Before: 0.01478 seconds
Time After: 0.01699 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01407 seconds
Time After: 0.02170 seconds
Time Taken: 0.00763 seconds
Time Before: 0.02503 seconds
Time After: 0.02521 seconds
Time Before: 0.02680 seconds
Time After: 0.02804 seconds
Time Before: 0.02431 seconds
Time After: 0.02827 seconds
Time Taken: 0.00396 seconds
Time Before: 0.05405 seconds
Time After: 0.05419 seconds
Time Before: 0.06382 seconds
Time After: 0.06507 seconds
Time Before: 0.07246 seconds
Time After: 0.07264 seconds
Time Before: 0.07528 seconds
Time After: 0.07672 seconds
UPDATE session SET lastactivity = 1785289954, location = '/forums/private.php?do=newpm&explain=1&u=125343', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.09380 seconds
Time After: 0.09414 seconds
