Time Before: 0.01362 seconds
Time After: 0.01559 seconds
Time Taken: 0.00198 seconds
Time Before: 0.01569 seconds
Time After: 0.01620 seconds
Time Before: 0.01645 seconds
Time After: 0.01657 seconds
Time Before: 0.01739 seconds
Time After: 0.01991 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01663 seconds
Time After: 0.02373 seconds
Time Taken: 0.00709 seconds
Time Before: 0.02973 seconds
Time After: 0.03014 seconds
Time Before: 0.03283 seconds
Time After: 0.03401 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02909 seconds
Time After: 0.03422 seconds
Time Taken: 0.00513 seconds
Time Before: 0.05278 seconds
Time After: 0.05292 seconds
Time Before: 0.06277 seconds
Time After: 0.06404 seconds
End call of global.php: 0.065909147262573
Time Before: 0.07121 seconds
Time After: 0.07139 seconds
Time Before: 0.07353 seconds
Time After: 0.07493 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1783144237, location = '/forums/private.php?do=newpm&explain=1&u=125369', badlocation = 1
Time Before: 0.09111 seconds
Time After: 0.09144 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
Page generated in 0.090152978897095 seconds with 9 queries, spending 0.0080540180206299 doing MySQL queries and 0.082098960876465 doing PHP things.
