Time Before: 0.00527 seconds
Time After: 0.00675 seconds
Time Before: 0.00683 seconds
Time After: 0.00734 seconds
Time Before: 0.00762 seconds
Time After: 0.00778 seconds
Time Before: 0.00856 seconds
Time After: 0.01144 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00784 seconds
Time After: 0.01578 seconds
Time Taken: 0.00793 seconds
Time Before: 0.01821 seconds
Time After: 0.01865 seconds
Time Before: 0.02126 seconds
Time After: 0.02265 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01748 seconds
Time After: 0.02291 seconds
Time Taken: 0.00543 seconds
Time Before: 0.03362 seconds
Time After: 0.03384 seconds
Time Before: 0.03646 seconds
Time After: 0.03769 seconds
Time Before: 0.04091 seconds
Time After: 0.04115 seconds
Time Before: 0.04334 seconds
Time After: 0.04479 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=125411', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.06026 seconds
Time After: 0.06052 seconds
