Time Before: 0.00153 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00250 seconds
Time Before: 0.00282 seconds
Time After: 0.00299 seconds
Time Before: 0.00383 seconds
Time After: 0.00612 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00304 seconds
Time After: 0.01172 seconds
Time Taken: 0.00868 seconds
Time Before: 0.01360 seconds
Time After: 0.01398 seconds
Time Before: 0.01658 seconds
Time After: 0.01781 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01297 seconds
Time After: 0.01808 seconds
Time Taken: 0.00511 seconds
Memory After: 2,261.703 KB
Time Before: 0.02490 seconds
Time After: 0.02512 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02742 seconds
Time After: 0.02906 seconds
Time Taken: 0.00164 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.031630039215088
Time Before: 0.03309 seconds
Time After: 0.03329 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03611 seconds
Time After: 0.03761 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=125468'
Time Before: 0.05221 seconds
Time After: 0.05256 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.051270961761475 seconds with 9 queries, spending 0.0084257125854492 doing MySQL queries and 0.042845249176025 doing PHP things.
