Time Before: 0.02424 seconds
Time After: 0.03128 seconds
Time Taken: 0.00704 seconds
Time Before: 0.03138 seconds
Time After: 0.03186 seconds
Time Before: 0.03214 seconds
Time After: 0.03229 seconds
Time Before: 0.03315 seconds
Time After: 0.03596 seconds
Time Taken: 0.00280 seconds
Time Before: 0.03237 seconds
Time After: 0.04084 seconds
Time Taken: 0.00847 seconds
Time Before: 0.04948 seconds
Time After: 0.04997 seconds
Time Before: 0.05264 seconds
Time After: 0.05387 seconds
Time Before: 0.04880 seconds
Time After: 0.05411 seconds
Time Taken: 0.00531 seconds
Time Before: 0.09552 seconds
Time After: 0.09570 seconds
Time Before: 0.11285 seconds
Time After: 0.11425 seconds
Time Taken: 0.00140 seconds
End call of global.php: 0.11661601066589
Time Before: 0.12309 seconds
Time After: 0.12327 seconds
Time Before: 0.12592 seconds
Time After: 0.12737 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=125474', badlocation = 1
WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.14694 seconds
Time After: 0.14722 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.14580202102661 seconds with 9 queries, spending 0.0086400508880615 doing MySQL queries and 0.13716197013855 doing PHP things.
