Time Before: 0.00155 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00277 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00305 seconds
Time After: 0.00317 seconds
Time Before: 0.00394 seconds
Time After: 0.00644 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00322 seconds
Time After: 0.00985 seconds
Time Taken: 0.00663 seconds
Time Before: 0.01230 seconds
Time After: 0.01282 seconds
Time Before: 0.01594 seconds
Time After: 0.01719 seconds
Time Before: 0.01156 seconds
Time After: 0.01743 seconds
Time Taken: 0.00587 seconds
Time Before: 0.02297 seconds
Time After: 0.02315 seconds
Time Before: 0.02549 seconds
Time After: 0.02671 seconds
End call of global.php: 0.028535842895508
Time Before: 0.03031 seconds
Time After: 0.03053 seconds
Time Before: 0.03325 seconds
Time After: 0.03550 seconds
Time Taken: 0.00224 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=125496', badlocation = 1
Time Before: 0.05453 seconds
Time After: 0.05486 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.05349588394165 seconds with 9 queries, spending 0.0092148780822754 doing MySQL queries and 0.044281005859375 doing PHP things.
