Time Before: 0.02031 seconds
Time After: 0.02957 seconds
Time Taken: 0.00925 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.02966 seconds
Time After: 0.03028 seconds
Time Taken: 0.00062 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.03056 seconds
Time After: 0.03074 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.03159 seconds
Time After: 0.03458 seconds
Time Taken: 0.00298 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.03080 seconds
Time After: 0.03872 seconds
Time Taken: 0.00792 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.04827 seconds
Time After: 0.04867 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.05116 seconds
Time After: 0.05393 seconds
Time Taken: 0.00277 seconds
Memory Before: 2,147.313 KB
Memory After: 2,147.172 KB
Time Before: 0.04760 seconds
Time After: 0.05420 seconds
Time Taken: 0.00660 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.523 KB
Memory Used: 133.094 KB
Time Before: 0.09264 seconds
Time After: 0.09281 seconds
Memory Before: 2,814.047 KB
Memory After: 2,814.563 KB
Time Before: 0.11286 seconds
Time After: 0.11418 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,902.336 KB
Memory After: 2,902.930 KB
End call of global.php: 0.11627221107483
Time Before: 0.12246 seconds
Time After: 0.12264 seconds
Memory Before: 3,539.156 KB
Memory After: 3,539.586 KB
Time Before: 0.12533 seconds
Time After: 0.12769 seconds
Time Taken: 0.00236 seconds
Memory Before: 3,820.688 KB
Memory After: 3,822.375 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=125504', badlocation = 1
Time Before: 0.14554 seconds
Time After: 0.14587 seconds
Memory Before: 4,299.023 KB
Memory After: 4,299.250 KB
Page generated in 0.14460706710815 seconds with 9 queries, spending 0.011311292648315 doing MySQL queries and 0.13329577445984 doing PHP things.
