Time Before: 0.00166 seconds
Time After: 0.00227 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00234 seconds
Time After: 0.00270 seconds
Time Before: 0.00291 seconds
Time After: 0.00303 seconds
Time Before: 0.00366 seconds
Time After: 0.00588 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00308 seconds
Time After: 0.00929 seconds
Time Taken: 0.00621 seconds
Time Before: 0.01118 seconds
Time After: 0.01162 seconds
Time Before: 0.01433 seconds
Time After: 0.01558 seconds
Time Before: 0.01057 seconds
Time After: 0.01575 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02167 seconds
Time After: 0.02179 seconds
Time Before: 0.02359 seconds
Time After: 0.02481 seconds
End call of global.php: 0.026443958282471
Time Before: 0.02784 seconds
Time After: 0.02799 seconds
Time Before: 0.03003 seconds
Time After: 0.03145 seconds
SET lastactivity = 1776794288, location = '/forums/private.php?do=newpm&explain=1&u=125526', badlocation = 1
Time Before: 0.04420 seconds
Time After: 0.04456 seconds
Page generated in 0.043282032012939 seconds with 9 queries, spending 0.0076770782470703 doing MySQL queries and 0.035604953765869 doing PHP things.
