Time Before: 0.01341 seconds
Time After: 0.01565 seconds
Time Taken: 0.00224 seconds
Time Before: 0.01573 seconds
Time After: 0.01614 seconds
Time Before: 0.01637 seconds
Time After: 0.01651 seconds
Time Before: 0.01735 seconds
Time After: 0.01974 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01659 seconds
Time After: 0.02402 seconds
Time Taken: 0.00743 seconds
Time Before: 0.02792 seconds
Time After: 0.02842 seconds
Time Before: 0.03104 seconds
Time After: 0.03221 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02724 seconds
Time After: 0.03242 seconds
Time Taken: 0.00518 seconds
Time Before: 0.05950 seconds
Time After: 0.05964 seconds
Time Before: 0.07022 seconds
Time After: 0.07149 seconds
End call of global.php: 0.073408842086792
Time Before: 0.07741 seconds
Time After: 0.07756 seconds
Time Before: 0.07982 seconds
Time After: 0.08129 seconds
SET lastactivity = 1784791723, location = '/forums/private.php?do=newpm&explain=1&u=125550'
Time Before: 0.09753 seconds
Time After: 0.09776 seconds
Page generated in 0.096525907516479 seconds with 9 queries, spending 0.0078690052032471 doing MySQL queries and 0.088656902313232 doing PHP things.
