Time Before: 0.00172 seconds
Time After: 0.00234 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00240 seconds
Time After: 0.00282 seconds
Time Before: 0.00301 seconds
Time After: 0.00317 seconds
Time Before: 0.00399 seconds
Time After: 0.00643 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00335 seconds
Time After: 0.01112 seconds
Time Taken: 0.00777 seconds
Time Before: 0.01297 seconds
Time After: 0.01339 seconds
Time Before: 0.01590 seconds
Time After: 0.01715 seconds
Time Before: 0.01239 seconds
Time After: 0.01732 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02224 seconds
Time After: 0.02235 seconds
Time Before: 0.02445 seconds
Time After: 0.02576 seconds
Time Taken: 0.00132 seconds
Time Before: 0.02856 seconds
Time After: 0.02872 seconds
Time Before: 0.03061 seconds
Time After: 0.03208 seconds
UPDATE session SET lastactivity = 1780621274, location = '/forums/private.php?do=newpm&explain=1&u=125562' WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04485 seconds
Time After: 0.04515 seconds
