Time Before: 0.00164 seconds
Time After: 0.00230 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00239 seconds
Time After: 0.00285 seconds
Time Before: 0.00321 seconds
Time After: 0.00337 seconds
Time Before: 0.00412 seconds
Time After: 0.00677 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00342 seconds
Time After: 0.01018 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01204 seconds
Time After: 0.01246 seconds
Time Before: 0.01490 seconds
Time After: 0.01606 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01146 seconds
Time After: 0.01624 seconds
Time Taken: 0.00477 seconds
Memory After: 2,261.703 KB
Time Before: 0.02513 seconds
Time After: 0.02530 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02728 seconds
Time After: 0.02855 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.031167984008789
Time Before: 0.03312 seconds
Time After: 0.03334 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03577 seconds
Time After: 0.03867 seconds
Time Taken: 0.00290 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=125594'
Time Before: 0.05143 seconds
Time After: 0.05189 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.050542831420898 seconds with 9 queries, spending 0.0098328590393066 doing MySQL queries and 0.040709972381592 doing PHP things.
