Time Before: 0.00146 seconds
Time After: 0.00196 seconds
Time Before: 0.00204 seconds
Time After: 0.00276 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00315 seconds
Time After: 0.00335 seconds
Time Before: 0.00411 seconds
Time After: 0.00730 seconds
Time Taken: 0.00319 seconds
Time Before: 0.00342 seconds
Time After: 0.01070 seconds
Time Taken: 0.00728 seconds
Time Before: 0.01302 seconds
Time After: 0.01347 seconds
Time Before: 0.01644 seconds
Time After: 0.01780 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01232 seconds
Time After: 0.01797 seconds
Time Taken: 0.00566 seconds
Time Before: 0.02289 seconds
Time After: 0.02311 seconds
Time Before: 0.02492 seconds
Time After: 0.02616 seconds
End call of global.php: 0.027769804000854
Time Before: 0.02897 seconds
Time After: 0.02919 seconds
Time Before: 0.03120 seconds
Time After: 0.03269 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=125598'
Time Before: 0.04512 seconds
Time After: 0.04552 seconds
Page generated in 0.044230937957764 seconds with 9 queries, spending 0.0094959735870361 doing MySQL queries and 0.034734964370728 doing PHP things.
