Time Before: 0.00149 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00249 seconds
Time Before: 0.00275 seconds
Time After: 0.00286 seconds
Time Before: 0.00361 seconds
Time After: 0.00612 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00291 seconds
Time After: 0.00952 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01131 seconds
Time After: 0.01173 seconds
Time Before: 0.01454 seconds
Time After: 0.01587 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01070 seconds
Time After: 0.01604 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02132 seconds
Time After: 0.02255 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"26.76,\";s:9:\"lastcheck\";i:1780665423;}', 1)Time Before: 0.02853 seconds
Time After: 0.02935 seconds
Time Taken: 0.00082 seconds
Memory Before: 2,817.297 KB
Memory After: 2,817.547 KB
Memory Used: 0.250 KB
Time Before: 0.03258 seconds
Time After: 0.03382 seconds
Memory Before: 2,904.602 KB
Memory After: 2,905.195 KB
Time Before: 0.03789 seconds
Time After: 0.03808 seconds
Memory Before: 3,541.359 KB
Memory After: 3,541.789 KB
Time Before: 0.04046 seconds
Time After: 0.04198 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,823.094 KB
Memory After: 3,824.781 KB
UPDATE session SET lastactivity = 1780665423, location = '/forums/private.php?do=newpm&explain=1&u=125681', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.05821 seconds
Time After: 0.05852 seconds
Memory Before: 4,297.086 KB
Memory After: 4,297.297 KB
