Time Before: 0.00189 seconds
Time After: 0.00247 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00254 seconds
Time After: 0.00306 seconds
Time Before: 0.00334 seconds
Time After: 0.00348 seconds
Time Before: 0.00439 seconds
Time After: 0.00734 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00356 seconds
Time After: 0.01076 seconds
Time Taken: 0.00720 seconds
Time Before: 0.01260 seconds
Time After: 0.01296 seconds
Time Before: 0.01424 seconds
Time After: 0.01550 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01199 seconds
Time After: 0.01567 seconds
Time Taken: 0.00368 seconds
Memory After: 2,261.820 KB
Time Before: 0.02061 seconds
Time After: 0.02076 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02448 seconds
Time After: 0.02571 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.027331829071045
Time Before: 0.02846 seconds
Time After: 0.02863 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03063 seconds
Time After: 0.03208 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789110378, location = '/forums/private.php?do=newpm&explain=1&u=125717', badlocation = 1
Time Before: 0.04426 seconds
Time After: 0.04466 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.043363809585571 seconds with 9 queries, spending 0.0086281299591064 doing MySQL queries and 0.034735679626465 doing PHP things.
