Time Before: 0.01640 seconds
Time After: 0.02360 seconds
Time Taken: 0.00720 seconds
Time Before: 0.02370 seconds
Time After: 0.02445 seconds
Time Taken: 0.00075 seconds
Time Before: 0.02485 seconds
Time After: 0.02498 seconds
Time Before: 0.02586 seconds
Time After: 0.02905 seconds
Time Taken: 0.00319 seconds
Time Before: 0.02507 seconds
Time After: 0.03305 seconds
Time Taken: 0.00798 seconds
Time Before: 0.04141 seconds
Time After: 0.04183 seconds
Time Before: 0.04426 seconds
Time After: 0.04548 seconds
Time Before: 0.04068 seconds
Time After: 0.04571 seconds
Time Taken: 0.00503 seconds
Time Before: 0.07828 seconds
Time After: 0.07845 seconds
Time Before: 0.09378 seconds
Time After: 0.09509 seconds
Time Taken: 0.00131 seconds
Time Before: 0.10554 seconds
Time After: 0.10586 seconds
Time Before: 0.10838 seconds
Time After: 0.10983 seconds
UPDATE session SET lastactivity = 1783235080, location = '/forums/private.php?do=newpm&explain=1&u=125723' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.12755 seconds
Time After: 0.12786 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
