Time Before: 0.01853 seconds
Time After: 0.02508 seconds
Time Taken: 0.00655 seconds
Time Before: 0.02519 seconds
Time After: 0.02568 seconds
Time Before: 0.02595 seconds
Time After: 0.02612 seconds
Time Before: 0.02688 seconds
Time After: 0.02927 seconds
Time Taken: 0.00239 seconds
Time Before: 0.02618 seconds
Time After: 0.03333 seconds
Time Taken: 0.00715 seconds
Time Before: 0.04136 seconds
Time After: 0.04174 seconds
Time Before: 0.04438 seconds
Time After: 0.04563 seconds
Time Before: 0.04055 seconds
Time After: 0.04590 seconds
Time Taken: 0.00536 seconds
Time Before: 0.08741 seconds
Time After: 0.08755 seconds
Time Before: 0.10157 seconds
Time After: 0.10282 seconds
Time Before: 0.10979 seconds
Time After: 0.10998 seconds
Time Before: 0.11262 seconds
Time After: 0.11406 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=125736', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.13418 seconds
Time After: 0.13444 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
