Time Before: 0.03263 seconds
Time After: 0.04115 seconds
Time Taken: 0.00852 seconds
Time Before: 0.04123 seconds
Time After: 0.04168 seconds
Time Before: 0.04194 seconds
Time After: 0.04208 seconds
Time Before: 0.04280 seconds
Time After: 0.04496 seconds
Time Taken: 0.00215 seconds
Time Before: 0.04214 seconds
Time After: 0.04980 seconds
Time Taken: 0.00766 seconds
Time Before: 0.06337 seconds
Time After: 0.06377 seconds
Time Before: 0.06630 seconds
Time After: 0.06755 seconds
Time Before: 0.06264 seconds
Time After: 0.06778 seconds
Time Taken: 0.00514 seconds
Time Before: 0.11873 seconds
Time After: 0.11891 seconds
Time Before: 0.15113 seconds
Time After: 0.15238 seconds
Time Before: 0.16105 seconds
Time After: 0.16123 seconds
Time Before: 0.16363 seconds
Time After: 0.16512 seconds
UPDATE session SET lastactivity = 1776685133, location = '/forums/private.php?do=newpm&explain=1&u=125768' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.18199 seconds
Time After: 0.18228 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
