Time Before: 0.02305 seconds
Time After: 0.03042 seconds
Time Taken: 0.00737 seconds
Time Before: 0.03052 seconds
Time After: 0.03129 seconds
Time Taken: 0.00077 seconds
Time Before: 0.03153 seconds
Time After: 0.03167 seconds
Time Before: 0.03254 seconds
Time After: 0.03545 seconds
Time Taken: 0.00291 seconds
Time Before: 0.03174 seconds
Time After: 0.03963 seconds
Time Taken: 0.00789 seconds
Time Before: 0.04960 seconds
Time After: 0.04983 seconds
Time Before: 0.05228 seconds
Time After: 0.05348 seconds
Time Before: 0.04896 seconds
Time After: 0.05372 seconds
Time Taken: 0.00476 seconds
Time Before: 0.08983 seconds
Time After: 0.09000 seconds
Time Before: 0.14483 seconds
Time After: 0.14619 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.14913105964661
Time Before: 0.15535 seconds
Time After: 0.15553 seconds
Time Before: 0.15813 seconds
Time After: 0.15958 seconds
SET lastactivity = 1776452493, location = '/forums/private.php?do=newpm&explain=1&u=125777', badlocation = 1
Time Before: 0.17872 seconds
Time After: 0.17895 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.1777720451355 seconds with 9 queries, spending 0.0086371898651123 doing MySQL queries and 0.16913485527039 doing PHP things.
