Time Before: 0.00597 seconds
Time After: 0.00822 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00831 seconds
Time After: 0.00877 seconds
Time Before: 0.00903 seconds
Time After: 0.00917 seconds
Time Before: 0.00992 seconds
Time After: 0.01299 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00924 seconds
Time After: 0.01740 seconds
Time Taken: 0.00815 seconds
Time Before: 0.02126 seconds
Time After: 0.02167 seconds
Time Before: 0.02419 seconds
Time After: 0.02541 seconds
Time Before: 0.02060 seconds
Time After: 0.02564 seconds
Time Taken: 0.00504 seconds
Time Before: 0.03886 seconds
Time After: 0.04406 seconds
Time Taken: 0.00520 seconds
Time Before: 0.05653 seconds
Time After: 0.05797 seconds
End call of global.php: 0.060935020446777
Time Before: 0.06578 seconds
Time After: 0.06596 seconds
Time Before: 0.06850 seconds
Time After: 0.06996 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=125782', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.08904 seconds
Time After: 0.09116 seconds
Time Taken: 0.00212 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.087833881378174 seconds with 9 queries, spending 0.015708923339844 doing MySQL queries and 0.07212495803833 doing PHP things.
