Time Before: 0.02551 seconds
Time After: 0.03846 seconds
Time Taken: 0.01295 seconds
Time Before: 0.03857 seconds
Time After: 0.03900 seconds
Time Before: 0.03925 seconds
Time After: 0.03940 seconds
Time Before: 0.04013 seconds
Time After: 0.04253 seconds
Time Taken: 0.00240 seconds
Time Before: 0.03947 seconds
Time After: 0.04638 seconds
Time Taken: 0.00691 seconds
Time Before: 0.06099 seconds
Time After: 0.06142 seconds
Time Before: 0.06425 seconds
Time After: 0.06550 seconds
Time Before: 0.06029 seconds
Time After: 0.06570 seconds
Time Taken: 0.00541 seconds
Time Before: 0.10464 seconds
Time After: 0.10477 seconds
Time Before: 0.13594 seconds
Time After: 0.13716 seconds
End call of global.php: 0.13945007324219
Time Before: 0.14885 seconds
Time After: 0.14902 seconds
Time Before: 0.15133 seconds
Time After: 0.15276 seconds
SET lastactivity = 1785303599, location = '/forums/private.php?do=newpm&explain=1&u=125851', badlocation = 1
Time Before: 0.17312 seconds
Time After: 0.17340 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.17204093933105 seconds with 9 queries, spending 0.0078845024108887 doing MySQL queries and 0.16415643692017 doing PHP things.
