Time Before: 0.00197 seconds
Time After: 0.00341 seconds
Time Before: 0.00348 seconds
Time After: 0.00403 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00434 seconds
Time After: 0.00455 seconds
Time Before: 0.00556 seconds
Time After: 0.00880 seconds
Time Taken: 0.00323 seconds
Time Before: 0.00464 seconds
Time After: 0.01367 seconds
Time Taken: 0.00903 seconds
Time Before: 0.01594 seconds
Time After: 0.01645 seconds
Time Before: 0.01966 seconds
Time After: 0.02092 seconds
Time Before: 0.01518 seconds
Time After: 0.02110 seconds
Time Taken: 0.00592 seconds
Time Before: 0.02614 seconds
Time After: 0.02627 seconds
Time Before: 0.02843 seconds
Time After: 0.02968 seconds
Time Before: 0.03326 seconds
Time After: 0.03346 seconds
Time Before: 0.03561 seconds
Time After: 0.03705 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=125859' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04940 seconds
Time After: 0.05011 seconds
Time Taken: 0.00071 seconds
