Time Before: 0.01959 seconds
Time After: 0.02756 seconds
Time Taken: 0.00797 seconds
Time Before: 0.02768 seconds
Time After: 0.02825 seconds
Time Taken: 0.00058 seconds
Time Before: 0.02850 seconds
Time After: 0.02865 seconds
Time Before: 0.02940 seconds
Time After: 0.03180 seconds
Time Taken: 0.00240 seconds
Time Before: 0.02872 seconds
Time After: 0.03669 seconds
Time Before: 0.04335 seconds
Time After: 0.04378 seconds
Time Before: 0.04645 seconds
Time After: 0.04767 seconds
Time Before: 0.04270 seconds
Time After: 0.04790 seconds
Time Taken: 0.00521 seconds
Time Before: 0.07557 seconds
Time After: 0.07580 seconds
Time Before: 0.09361 seconds
Time After: 0.09489 seconds
End call of global.php: 0.097601890563965
Time Before: 0.10218 seconds
Time After: 0.10236 seconds
Time Before: 0.10522 seconds
Time After: 0.10670 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=125860', badlocation = 1
Time Before: 0.12485 seconds
Time After: 0.12512 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.12385106086731 seconds with 9 queries, spending 0.0082268714904785 doing MySQL queries and 0.11562418937683 doing PHP things.
