Time Before: 0.01198 seconds
Time After: 0.01777 seconds
Time Taken: 0.00578 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01787 seconds
Time After: 0.01831 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01857 seconds
Time After: 0.01868 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01941 seconds
Time After: 0.02198 seconds
Time Taken: 0.00257 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.01874 seconds
Time After: 0.02592 seconds
Time Taken: 0.00718 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.03117 seconds
Time After: 0.03154 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.03437 seconds
Time After: 0.03555 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.03059 seconds
Time After: 0.03576 seconds
Time Taken: 0.00517 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.06300 seconds
Time After: 0.06314 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.07713 seconds
Time After: 0.07848 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
Time Before: 0.08894 seconds
Time After: 0.08911 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.09201 seconds
Time After: 0.09348 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
UPDATE session SET lastactivity = 1784989099, location = '/forums/private.php?do=newpm&explain=1&u=125914', badlocation = 1 WHERE sessionhash = 'e0f24550e916c0d25518ad14fd8d75f0'
Time Before: 0.11190 seconds
Time After: 0.11218 seconds
Memory Before: 4,296.195 KB
Memory After: 4,296.406 KB
