Time Before: 0.01450 seconds
Time After: 0.01763 seconds
Time Taken: 0.00314 seconds
Time Before: 0.01770 seconds
Time After: 0.01806 seconds
Time Before: 0.01835 seconds
Time After: 0.01851 seconds
Time Before: 0.01938 seconds
Time After: 0.02197 seconds
Time Taken: 0.00259 seconds
Time Before: 0.01857 seconds
Time After: 0.02652 seconds
Time Taken: 0.00794 seconds
Time Before: 0.03892 seconds
Time After: 0.03930 seconds
Time Before: 0.04186 seconds
Time After: 0.04320 seconds
Time Taken: 0.00134 seconds
Time Before: 0.03813 seconds
Time After: 0.04345 seconds
Time Taken: 0.00532 seconds
Time Before: 0.06617 seconds
Time After: 0.06632 seconds
Time Before: 0.07543 seconds
Time After: 0.07674 seconds
Time Taken: 0.00131 seconds
Time Before: 0.08570 seconds
Time After: 0.08588 seconds
Time Before: 0.08923 seconds
Time After: 0.09073 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1785351999, location = '/forums/private.php?do=newpm&explain=1&u=125942' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.10847 seconds
Time After: 0.10882 seconds
