Time Before: 0.02568 seconds
Time After: 0.03370 seconds
Time Taken: 0.00802 seconds
Time Before: 0.03383 seconds
Time After: 0.03438 seconds
Time Taken: 0.00055 seconds
Time Before: 0.03469 seconds
Time After: 0.03484 seconds
Time Before: 0.03549 seconds
Time After: 0.03779 seconds
Time Taken: 0.00230 seconds
Time Before: 0.03489 seconds
Time After: 0.04312 seconds
Time Taken: 0.00823 seconds
Time Before: 0.05442 seconds
Time After: 0.05474 seconds
Time Before: 0.05647 seconds
Time After: 0.05763 seconds
Time Taken: 0.00116 seconds
Time Before: 0.05382 seconds
Time After: 0.05781 seconds
Time Taken: 0.00399 seconds
Time Before: 0.10462 seconds
Time After: 0.10478 seconds
Time Before: 0.26102 seconds
Time After: 0.26288 seconds
Time Taken: 0.00185 seconds
End call of global.php: 0.26541614532471
Time Before: 0.27606 seconds
Time After: 0.27621 seconds
Time Before: 0.27916 seconds
Time After: 0.28059 seconds
SET lastactivity = 1776539709, location = '/forums/private.php?do=newpm&explain=1&u=126003'
Time Before: 0.30166 seconds
Time After: 0.30203 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.30062913894653 seconds with 9 queries, spending 0.008432149887085 doing MySQL queries and 0.29219698905945 doing PHP things.
