Time Before: 0.00408 seconds
Time After: 0.00525 seconds
Time Taken: 0.00117 seconds
Time Before: 0.00532 seconds
Time After: 0.00576 seconds
Time Before: 0.00598 seconds
Time After: 0.00610 seconds
Time Before: 0.00683 seconds
Time After: 0.00953 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00616 seconds
Time After: 0.01450 seconds
Time Taken: 0.00834 seconds
Time Before: 0.01633 seconds
Time After: 0.01683 seconds
Time Before: 0.01960 seconds
Time After: 0.02101 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01566 seconds
Time After: 0.02126 seconds
Time Taken: 0.00560 seconds
Memory After: 2,261.703 KB
Time Before: 0.03129 seconds
Time After: 0.03144 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03498 seconds
Time After: 0.03642 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.04016 seconds
Time After: 0.04032 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.04235 seconds
Time After: 0.04378 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=126023', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05624 seconds
Time After: 0.05652 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
