Time Before: 0.00403 seconds
Time After: 0.00552 seconds
Memory Before: 532.289 KB
Memory After: 557.406 KB
Time Before: 0.00562 seconds
Time After: 0.00599 seconds
Memory Before: 557.344 KB
Memory After: 558.352 KB
Time Before: 0.00623 seconds
Time After: 0.00636 seconds
Memory Before: 558.906 KB
Memory After: 559.430 KB
Time Before: 0.00728 seconds
Time After: 0.00950 seconds
Time Taken: 0.00222 seconds
Memory Before: 562.031 KB
Memory After: 562.953 KB
Time Before: 0.00641 seconds
Time After: 0.01442 seconds
Time Taken: 0.00800 seconds
Memory Before: 558.680 KB
Memory After: 1,639.734 KB
Memory Used: 1,081.055 KB
Time Before: 0.01785 seconds
Time After: 0.01823 seconds
Memory Before: 2,134.656 KB
Memory After: 2,135.273 KB
Time Before: 0.02138 seconds
Time After: 0.02272 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,146.836 KB
Memory After: 2,146.695 KB
Time Before: 0.01699 seconds
Time After: 0.02303 seconds
Time Taken: 0.00604 seconds
Memory Before: 2,126.836 KB
Memory After: 2,260.047 KB
Memory Used: 133.211 KB
Time Before: 0.02900 seconds
Time After: 0.02911 seconds
Memory Before: 2,813.594 KB
Memory After: 2,814.109 KB
Time Before: 0.03308 seconds
Time After: 0.03528 seconds
Time Taken: 0.00220 seconds
Memory Before: 2,901.883 KB
Memory After: 2,902.477 KB
End call of global.php: 0.037984132766724
Time Before: 0.04021 seconds
Time After: 0.04033 seconds
Memory Before: 3,538.656 KB
Memory After: 3,539.086 KB
Time Before: 0.04243 seconds
Time After: 0.04389 seconds
Memory Before: 3,820.188 KB
Memory After: 3,821.875 KB
SET lastactivity = 1789088393, location = '/forums/private.php?do=newpm&explain=1&u=126033', badlocation = 1
Time Before: 0.05743 seconds
Time After: 0.05809 seconds
Time Taken: 0.00067 seconds
Memory Before: 4,298.773 KB
Memory After: 4,298.984 KB
Page generated in 0.056551933288574 seconds with 9 queries, spending 0.008995532989502 doing MySQL queries and 0.047556400299072 doing PHP things.
