Time Before: 0.02152 seconds
Time After: 0.02880 seconds
Time Taken: 0.00728 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.02891 seconds
Time After: 0.02954 seconds
Time Taken: 0.00063 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.02991 seconds
Time After: 0.03022 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.03148 seconds
Time After: 0.03445 seconds
Time Taken: 0.00297 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.03035 seconds
Time After: 0.03870 seconds
Time Taken: 0.00835 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.04891 seconds
Time After: 0.04927 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.05168 seconds
Time After: 0.05286 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,770.180 KB
Memory After: 2,770.039 KB
Time Before: 0.04813 seconds
Time After: 0.05311 seconds
Time Taken: 0.00498 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.398 KB
Memory Used: 133.242 KB
Time Before: 0.09230 seconds
Time After: 0.09245 seconds
Memory Before: 3,436.508 KB
Memory After: 3,437.023 KB
Time Before: 0.11419 seconds
Time After: 0.11541 seconds
Memory Before: 3,524.281 KB
Memory After: 3,524.875 KB
Time Before: 0.12738 seconds
Time After: 0.12766 seconds
Memory Before: 4,162.195 KB
Memory After: 4,162.625 KB
Time Before: 0.13013 seconds
Time After: 0.13171 seconds
Time Taken: 0.00158 seconds
Memory Before: 4,443.734 KB
Memory After: 4,445.422 KB
UPDATE session SET lastactivity = 1776878573, location = '/forums/private.php?do=newpm&explain=1&u=126072', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.14928 seconds
Time After: 0.14987 seconds
Time Taken: 0.00059 seconds
Memory Before: 4,922.320 KB
Memory After: 4,922.531 KB
