Time Before: 0.00782 seconds
Time After: 0.01003 seconds
Time Taken: 0.00221 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.01015 seconds
Time After: 0.01064 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.01090 seconds
Time After: 0.01103 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01191 seconds
Time After: 0.01432 seconds
Time Taken: 0.00240 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.01110 seconds
Time After: 0.01866 seconds
Time Taken: 0.00755 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.02204 seconds
Time After: 0.02241 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.02514 seconds
Time After: 0.02636 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.02136 seconds
Time After: 0.02656 seconds
Time Taken: 0.00520 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.03912 seconds
Time After: 0.03928 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.04442 seconds
Time After: 0.04566 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.048017024993896
Time Before: 0.05176 seconds
Time After: 0.05192 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.05483 seconds
Time After: 0.05625 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=12609'
Time Before: 0.07297 seconds
Time After: 0.07330 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.071969032287598 seconds with 9 queries, spending 0.0079348087310791 doing MySQL queries and 0.064034223556519 doing PHP things.
