Time Before: 0.00220 seconds
Time After: 0.00275 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00281 seconds
Time After: 0.00327 seconds
Time Before: 0.00358 seconds
Time After: 0.00372 seconds
Time Before: 0.00467 seconds
Time After: 0.00749 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00380 seconds
Time After: 0.01090 seconds
Time Taken: 0.00710 seconds
Time Before: 0.01279 seconds
Time After: 0.01316 seconds
Time Before: 0.01561 seconds
Time After: 0.01695 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01215 seconds
Time After: 0.01715 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02360 seconds
Time After: 0.02378 seconds
Time Before: 0.02693 seconds
Time After: 0.02826 seconds
Time Before: 0.03110 seconds
Time After: 0.03147 seconds
Time Before: 0.03344 seconds
Time After: 0.03485 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=126108' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.04795 seconds
Time After: 0.04820 seconds
