Time Before: 0.00158 seconds
Time After: 0.00205 seconds
Time Before: 0.00212 seconds
Time After: 0.00264 seconds
Time Before: 0.00288 seconds
Time After: 0.00302 seconds
Time Before: 0.00386 seconds
Time After: 0.00647 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00310 seconds
Time After: 0.01160 seconds
Time Taken: 0.00850 seconds
Time Before: 0.01373 seconds
Time After: 0.01440 seconds
Time Taken: 0.00067 seconds
Time Before: 0.01629 seconds
Time After: 0.01753 seconds
Time Before: 0.01310 seconds
Time After: 0.01771 seconds
Time Taken: 0.00461 seconds
Time Before: 0.02320 seconds
Time After: 0.02334 seconds
Time Before: 0.02820 seconds
Time After: 0.02942 seconds
End call of global.php: 0.031651020050049
Time Before: 0.03385 seconds
Time After: 0.03401 seconds
Time Before: 0.03616 seconds
Time After: 0.03762 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=126114', badlocation = 1
Time Before: 0.05341 seconds
Time After: 0.05366 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.052453994750977 seconds with 9 queries, spending 0.0084166526794434 doing MySQL queries and 0.044037342071533 doing PHP things.
