Time Before: 0.00989 seconds
Time After: 0.01524 seconds
Time Taken: 0.00535 seconds
Time Before: 0.01531 seconds
Time After: 0.01573 seconds
Time Before: 0.01600 seconds
Time After: 0.01618 seconds
Time Before: 0.01692 seconds
Time After: 0.01956 seconds
Time Taken: 0.00264 seconds
Time Before: 0.01623 seconds
Time After: 0.02401 seconds
Time Taken: 0.00777 seconds
Time Before: 0.03079 seconds
Time After: 0.03121 seconds
Time Before: 0.03389 seconds
Time After: 0.03510 seconds
Time Before: 0.02982 seconds
Time After: 0.03535 seconds
Time Taken: 0.00553 seconds
Time Before: 0.05693 seconds
Time After: 0.05709 seconds
Time Before: 0.07105 seconds
Time After: 0.07248 seconds
End call of global.php: 0.074842214584351
Time Before: 0.08056 seconds
Time After: 0.08072 seconds
Time Before: 0.08339 seconds
Time After: 0.08485 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=126159', badlocation = 1
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.10596 seconds
Time After: 0.10628 seconds
Page generated in 0.10476803779602 seconds with 9 queries, spending 0.0084083080291748 doing MySQL queries and 0.096359729766846 doing PHP things.
