Time Before: 0.00185 seconds
Time After: 0.00244 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00255 seconds
Time After: 0.00300 seconds
Time Before: 0.00324 seconds
Time After: 0.00346 seconds
Time Before: 0.00414 seconds
Time After: 0.00695 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00351 seconds
Time After: 0.01036 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01338 seconds
Time After: 0.01422 seconds
Time Taken: 0.00084 seconds
Time Before: 0.01681 seconds
Time After: 0.01850 seconds
Time Taken: 0.00169 seconds
Time Before: 0.01219 seconds
Time After: 0.01869 seconds
Time Taken: 0.00650 seconds
Time Before: 0.02526 seconds
Time After: 0.02540 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:5:\"8.56,\";s:9:\"lastcheck\";i:1789129855;}', 1)Time Before: 0.03224 seconds
Time After: 0.03255 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.03562 seconds
Time After: 0.03689 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.04236 seconds
Time After: 0.04281 seconds
Memory Before: 4,164.359 KB
Memory After: 4,164.789 KB
Time Before: 0.04521 seconds
Time After: 0.04672 seconds
Time Taken: 0.00150 seconds
Memory Before: 4,446.148 KB
Memory After: 4,447.836 KB
UPDATE session SET lastactivity = 1789129855, location = '/forums/private.php?do=newpm&explain=1&u=126205' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05946 seconds
Time After: 0.05979 seconds
Memory Before: 4,919.797 KB
Memory After: 4,920.023 KB
