Time Before: 0.02597 seconds
Time After: 0.03516 seconds
Time Taken: 0.00919 seconds
Time Before: 0.03525 seconds
Time After: 0.03570 seconds
Time Before: 0.03601 seconds
Time After: 0.03618 seconds
Time Before: 0.03700 seconds
Time After: 0.03889 seconds
Time Taken: 0.00189 seconds
Time Before: 0.03624 seconds
Time After: 0.04307 seconds
Time Taken: 0.00682 seconds
Time Before: 0.05369 seconds
Time After: 0.05412 seconds
Time Before: 0.05549 seconds
Time After: 0.05671 seconds
Time Before: 0.05297 seconds
Time After: 0.05695 seconds
Time Taken: 0.00397 seconds
Time Before: 0.10679 seconds
Time After: 0.10697 seconds
Time Before: 0.13098 seconds
Time After: 0.13224 seconds
Time Before: 0.14415 seconds
Time After: 0.14433 seconds
Time Before: 0.14758 seconds
Time After: 0.14946 seconds
Time Taken: 0.00187 seconds
UPDATE session SET lastactivity = 1789110509, location = '/forums/private.php?do=newpm&explain=1&u=126228' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.16786 seconds
Time After: 0.18126 seconds
Time Taken: 0.01340 seconds
