Time Before: 0.01513 seconds
Time After: 0.01837 seconds
Time Taken: 0.00324 seconds
Time Before: 0.01848 seconds
Time After: 0.01893 seconds
Time Before: 0.01917 seconds
Time After: 0.01935 seconds
Time Before: 0.02015 seconds
Time After: 0.02265 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01943 seconds
Time After: 0.02607 seconds
Time Taken: 0.00664 seconds
Time Before: 0.02923 seconds
Time After: 0.02965 seconds
Time Before: 0.03258 seconds
Time After: 0.03387 seconds
Time Before: 0.02855 seconds
Time After: 0.03409 seconds
Time Taken: 0.00554 seconds
Time Before: 0.05585 seconds
Time After: 0.05602 seconds
Time Before: 0.06731 seconds
Time After: 0.06858 seconds
End call of global.php: 0.070534944534302
Time Before: 0.07547 seconds
Time After: 0.07570 seconds
Time Before: 0.07796 seconds
Time After: 0.07945 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=126247', badlocation = 1
Time Before: 0.09748 seconds
Time After: 0.09778 seconds
Page generated in 0.096468925476074 seconds with 9 queries, spending 0.0082738399505615 doing MySQL queries and 0.088195085525513 doing PHP things.
