Time Before: 0.00650 seconds
Time After: 0.00831 seconds
Time Taken: 0.00181 seconds
Time Before: 0.00841 seconds
Time After: 0.00879 seconds
Time Before: 0.00902 seconds
Time After: 0.00918 seconds
Time Before: 0.00993 seconds
Time After: 0.01231 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00924 seconds
Time After: 0.01796 seconds
Time Taken: 0.00871 seconds
Time Before: 0.02147 seconds
Time After: 0.02197 seconds
Time Before: 0.02517 seconds
Time After: 0.02756 seconds
Time Before: 0.02066 seconds
Time After: 0.02782 seconds
Time Taken: 0.00716 seconds
Time Before: 0.03975 seconds
Time After: 0.03989 seconds
Time Before: 0.04548 seconds
Time After: 0.04680 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.048922061920166
Time Before: 0.05197 seconds
Time After: 0.05216 seconds
Time Before: 0.05462 seconds
Time After: 0.05607 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=126273'
Time Before: 0.07595 seconds
Time After: 0.07628 seconds
Page generated in 0.074511051177979 seconds with 9 queries, spending 0.0092215538024902 doing MySQL queries and 0.065289497375488 doing PHP things.
