Time Before: 0.02065 seconds
Time After: 0.03071 seconds
Time Taken: 0.01006 seconds
Time Before: 0.03082 seconds
Time After: 0.03128 seconds
Time Before: 0.03155 seconds
Time After: 0.03172 seconds
Time Before: 0.03259 seconds
Time After: 0.03545 seconds
Time Taken: 0.00286 seconds
Time Before: 0.03178 seconds
Time After: 0.03988 seconds
Time Taken: 0.00811 seconds
Time Before: 0.05162 seconds
Time After: 0.05207 seconds
Time Before: 0.05463 seconds
Time After: 0.05596 seconds
Time Taken: 0.00133 seconds
Time Before: 0.05083 seconds
Time After: 0.05621 seconds
Time Taken: 0.00538 seconds
Time Before: 0.08815 seconds
Time After: 0.08832 seconds
Time Before: 0.11515 seconds
Time After: 0.11640 seconds
End call of global.php: 0.1185359954834
Time Before: 0.12721 seconds
Time After: 0.12739 seconds
Time Before: 0.12976 seconds
Time After: 0.13118 seconds
SET lastactivity = 1788893186, location = '/forums/private.php?do=newpm&explain=1&u=126331', badlocation = 1
Time Before: 0.14902 seconds
Time After: 0.14934 seconds
Page generated in 0.14788293838501 seconds with 9 queries, spending 0.0085916519165039 doing MySQL queries and 0.13929128646851 doing PHP things.
