Time Before: 0.02238 seconds
Time After: 0.03013 seconds
Time Taken: 0.00776 seconds
Time Before: 0.03024 seconds
Time After: 0.03171 seconds
Time Before: 0.03193 seconds
Time After: 0.03207 seconds
Time Before: 0.03297 seconds
Time After: 0.03527 seconds
Time Taken: 0.00229 seconds
Time Before: 0.03215 seconds
Time After: 0.03991 seconds
Time Before: 0.04862 seconds
Time After: 0.04900 seconds
Time Before: 0.05049 seconds
Time After: 0.05172 seconds
Time Before: 0.04786 seconds
Time After: 0.05191 seconds
Time Taken: 0.00405 seconds
Time Before: 0.09056 seconds
Time After: 0.09072 seconds
Time Before: 0.11351 seconds
Time After: 0.11478 seconds
End call of global.php: 0.11718511581421
Time Before: 0.12466 seconds
Time After: 0.12486 seconds
Time Before: 0.12803 seconds
Time After: 0.12950 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=126354', badlocation = 1
Time Before: 0.14982 seconds
Time After: 0.15011 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.1487250328064 seconds with 9 queries, spending 0.0088987350463867 doing MySQL queries and 0.13982629776001 doing PHP things.
