Time Before: 0.01479 seconds
Time After: 0.02057 seconds
Time Taken: 0.00578 seconds
Time Before: 0.02065 seconds
Time After: 0.02100 seconds
Time Before: 0.02125 seconds
Time After: 0.02141 seconds
Time Before: 0.02216 seconds
Time After: 0.02429 seconds
Time Taken: 0.00213 seconds
Time Before: 0.02149 seconds
Time After: 0.02826 seconds
Time Taken: 0.00678 seconds
Time Before: 0.03662 seconds
Time After: 0.03702 seconds
Time Before: 0.03972 seconds
Time After: 0.04094 seconds
Time Before: 0.03580 seconds
Time After: 0.04119 seconds
Time Taken: 0.00540 seconds
Time Before: 0.08277 seconds
Time After: 0.08292 seconds
Time Before: 0.09692 seconds
Time After: 0.09815 seconds
Time Before: 0.10873 seconds
Time After: 0.10889 seconds
Time Before: 0.11210 seconds
Time After: 0.11362 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1783157386, location = '/forums/private.php?do=newpm&explain=1&u=126488' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.13511 seconds
Time After: 0.13586 seconds
Time Taken: 0.00076 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
