Time Before: 0.03157 seconds
Time After: 0.03921 seconds
Time Taken: 0.00764 seconds
Time Before: 0.03931 seconds
Time After: 0.03979 seconds
Time Before: 0.04005 seconds
Time After: 0.04026 seconds
Time Before: 0.04108 seconds
Time After: 0.04383 seconds
Time Taken: 0.00275 seconds
Time Before: 0.04033 seconds
Time After: 0.04797 seconds
Time Before: 0.05900 seconds
Time After: 0.05923 seconds
Time Before: 0.06065 seconds
Time After: 0.06186 seconds
Time Before: 0.05826 seconds
Time After: 0.06208 seconds
Time Taken: 0.00382 seconds
Time Before: 0.11012 seconds
Time After: 0.11047 seconds
Time Before: 0.25139 seconds
Time After: 0.25273 seconds
Time Taken: 0.00134 seconds
Time Before: 0.26449 seconds
Time After: 0.26468 seconds
Time Before: 0.26781 seconds
Time After: 0.26930 seconds
UPDATE session SET lastactivity = 1783023952, location = '/forums/private.php?do=newpm&explain=1&u=126496', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.28814 seconds
Time After: 0.28844 seconds
