Time Before: 0.00142 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00263 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00290 seconds
Time After: 0.00307 seconds
Time Before: 0.00372 seconds
Time After: 0.00635 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00311 seconds
Time After: 0.00979 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01175 seconds
Time After: 0.01213 seconds
Time Before: 0.01424 seconds
Time After: 0.01559 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01115 seconds
Time After: 0.01579 seconds
Time Taken: 0.00464 seconds
Time Before: 0.02091 seconds
Time After: 0.02104 seconds
Time Before: 0.02312 seconds
Time After: 0.02436 seconds
Time Before: 0.02723 seconds
Time After: 0.02740 seconds
Time Before: 0.02940 seconds
Time After: 0.03083 seconds
UPDATE session SET lastactivity = 1788992327, location = '/forums/private.php?do=newpm&explain=1&u=126504', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04328 seconds
Time After: 0.04366 seconds
