Time Before: 0.02193 seconds
Time After: 0.02711 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02721 seconds
Time After: 0.02769 seconds
Time Before: 0.02798 seconds
Time After: 0.02815 seconds
Time Before: 0.02887 seconds
Time After: 0.03132 seconds
Time Taken: 0.00244 seconds
Time Before: 0.02821 seconds
Time After: 0.03539 seconds
Time Taken: 0.00718 seconds
Time Before: 0.04039 seconds
Time After: 0.04085 seconds
Time Before: 0.04354 seconds
Time After: 0.04564 seconds
Time Taken: 0.00210 seconds
Time Before: 0.03972 seconds
Time After: 0.04585 seconds
Time Taken: 0.00612 seconds
Time Before: 0.07725 seconds
Time After: 0.07740 seconds
Time Before: 0.08820 seconds
Time After: 0.08945 seconds
Time Before: 0.10145 seconds
Time After: 0.10163 seconds
Time Before: 0.10408 seconds
Time After: 0.10555 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=126515', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.12226 seconds
Time After: 0.12255 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
