Time Before: 0.01841 seconds
Time After: 0.02544 seconds
Time Taken: 0.00704 seconds
Time Before: 0.02553 seconds
Time After: 0.02593 seconds
Time Before: 0.02615 seconds
Time After: 0.02626 seconds
Time Before: 0.02708 seconds
Time After: 0.02973 seconds
Time Taken: 0.00265 seconds
Time Before: 0.02634 seconds
Time After: 0.03384 seconds
Time Taken: 0.00750 seconds
Time Before: 0.04285 seconds
Time After: 0.04311 seconds
Time Before: 0.04549 seconds
Time After: 0.04665 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04205 seconds
Time After: 0.04687 seconds
Time Taken: 0.00482 seconds
Time Before: 0.07897 seconds
Time After: 0.07916 seconds
Time Before: 0.51780 seconds
Time After: 0.51951 seconds
Time Taken: 0.00171 seconds
End call of global.php: 0.52185201644897
Time Before: 0.52801 seconds
Time After: 0.52820 seconds
Time Before: 0.53067 seconds
Time After: 0.53215 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=12657', badlocation = 1
Time Before: 0.55024 seconds
Time After: 0.55050 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.54928302764893 seconds with 9 queries, spending 0.0084164142608643 doing MySQL queries and 0.54086661338806 doing PHP things.
