Time Before: 0.00250 seconds
Time After: 0.00305 seconds
Time Taken: 0.00055 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00313 seconds
Time After: 0.00357 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00379 seconds
Time After: 0.00394 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00473 seconds
Time After: 0.00760 seconds
Time Taken: 0.00287 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00399 seconds
Time After: 0.01251 seconds
Time Taken: 0.00852 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01457 seconds
Time After: 0.01502 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01750 seconds
Time After: 0.01877 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01385 seconds
Time After: 0.01904 seconds
Time Taken: 0.00519 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02597 seconds
Time After: 0.02612 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03455 seconds
Time After: 0.03582 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.037669897079468
Time Before: 0.04645 seconds
Time After: 0.04662 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04915 seconds
Time After: 0.05060 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=126584'
Time Before: 0.06576 seconds
Time After: 0.06616 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
Page generated in 0.064838886260986 seconds with 9 queries, spending 0.008620023727417 doing MySQL queries and 0.056218862533569 doing PHP things.
